Old 04-13-2009, 12:27 AM
Default Re: 1978 SF restoration, my first one.....
.. a couple of things I'm hoping to accomplish will be able to accomodate a 175hp to 200hp 4 stroke engine with a 16-20 gallon livewell in the stern. At this point I'm thinking about purchasing one of Hermco's brackets for twins and having it drilled for a single for the additional flotation.
Will, it looks like you're off to a great start on your restoration! However I'd respectfully suggest you rethink the power selection, as the combo of a bracket, 500 lb motor (ask the mfgr what the WET weight is will all fluids and cowling installed!) and a big live well = a seriously stern heavy boat with a min planing speed of 20 mph plus! No matter how big the flotation chamber is, it won't help once you're on plane! Consider the Zuke 140 if you want quiet and low fuel consumption, or an early lightweight Merc if you want lots of power, or if you want quiet, lots of power AND low fuel comsumption, a small block V-6 E-Tec!
