Old 04-18-2009, 01:16 AM
htillman htillman is offline
Default Re: 1989 23WA Seacraft fuel tank replacemnt/maybe?
At a minimum, block/plug all connections - use a bicycle pump with a gage installed through a cork in one of the blocked lines and see if the tank holds pressure. If it does, then it is your risk to use. If is does not then you have no choice replace.
