Re: 1989 23WA Seacraft fuel tank replacemnt/maybe?
ET23, I would have to pull the engine and then there is no guarantee you could get that size back in the hole after all the trouble I had getting it out. I had to cut almost 3 feet off the tank and cut off the front side mounting brackets just to clear the end of the tunnel. I thank you for the advice, but it is just not practical to try and get it installed. I am thinking 75 gallons is a push. The old tank was 99 inches long,28 wide (w/27 inch hole) and 10 inches high for a 11-12 inch high tunnel. The replacement will have to be able to lay almost flat in the hole that is left open.
Gary
