Old 05-01-2009, 09:54 PM
gss036 gss036 is offline
Default Re: 1984 23 O/B Open - fuel tank capacity?
sasquatch, don't know if I would do that. When you run with real low fuel you stand the chance of all the junk on the bottom of the tank gets sloshed around and the junk ends up in you fuel filter. I did that on the 15th and ended up with a clogged filter and primer bulb sucked flat. Thanks goodness for a kicker.
Gary
