Old 05-21-2009, 07:13 PM
hermco hermco is offline
Default Re: Epoxy precautions and Construction tips
6. For replacing a core in a transom, he prefers stringers that run all the way to the outer skin with the core cut-out to fit over the stringers. That way the stringers are trapped by the core and more rigidly attached. He also prefers 45-degree braces or knees from stringer to transom.
7. He also likes the idea of a horizontal beam or shelf about 1x4 or 1x6 across the inside of the transom, as it provides significant stiffness to resist the bending loads that exist in a transom.
Why would you do this when the original transom design did not have or need it?
