Old 06-01-2009, 07:54 AM
Default Re: Man oh man, what a ride.
Your gear ratio is fine. Your prop needs changing.
Allow me to use a pickup truck as an analogy. The differential gearing is analogous to the lower unit gearing, and the tire diameter is analogous to the propeller pitch.
If I want to apply torque to the pavement more quickly I can change out the gears in my differential from the current 3.73:1 to 4.10:1 gears. If I do this, I will have better acceleration under load, higher rpms at cruise, lower axle rotation for a given rpm, and better responsiveness to power inputs.
OR, I can change my tires on the rear to a smaller diameter tire, which changes my applied drive ratio just like changing the diff gearing. Dropping from my current 265x75-16 tires to 245x65-16 tires gives me almost the exact same effective results as changing to 4.10 gears.
On the other hand, if I want to have lower rpms at cruise and a higher top speed, I can change the diff gearing to the optional 3.45:1 gears. This will reduce my acceleration, but give me lower rpms at a given speed, and probably increase my top speed.
OR, I can change my tires on the rear to a larger diameter tire, which changes my applied drive ratio just like changing the diff gearing. Increasing from my current 265x75-16 tires to 285x70-16 tires gives me almost the exact same effective results as changing to 3.45 gears.
In both cases, changing the tire size when it comes time to replace the tires costs a lot less, and produces the same results.
If your current gearset is undamaged, you can more economically change your effective power to thrust ratio by just changing the prop size.
Fr. Frank says:
Currently without a SeaCraft
