Old 06-28-2009, 12:37 PM
Default Re: 90 HP 4 cycle performance
Personally I don't think its nearly enough, you usually have to go up in HP to equal a 2S. Most 20's that go Zuke use the 140 and alot including me go all the way to 200. I just don't think it will work and could become very expensive trial. IMHO they need 140/150 to run correctly, I didn't say run, just correctly. I don't need all 200 but I damn sure don't want to send somebody to the bow to get on plane either. The boats Max HP was 150 then 175 - 90 is getting close to half that and 4 S's ain't the fastest in the arena anyway. In a more exotic description, the boat is designed to get up on the deeper deadrise center sections of the hull, to do that you need HP. The boat would just slog through and you would negate the advantage of the hull. If its on a Carolina Skiff with no deadrise fine but not a deep vee SC.
