Old 07-23-2009, 05:44 PM
joshmon71 joshmon71 is offline
Default Re: Is a Verado to heavy for my 79' 23' savage?
I gotta speak up as a verado owner...
Verados and not simple-There is absolutely nothing new about 4 stroke engines, and supercharging. Design the engine for an integrated SC not a bolt on. I don't buy that argument about Verados=more parts=less reliable. Time will tell, and I may eat my words.
Fuel and Verados-High test gas in verados is a myth...sort of. The 250 verado gen 1 runs on 87 nothing has changed on that, going higher buys you zilch. I have the 2005 250 shop manual on CD to confirm that. The 200-275 are the same block same weight, just computer diffs. To get 275 on the 275 gen 1 you ran 91 but it can run on 87 this is the Gen 1 motors. Its not the same for Gen 2 they are better as in double digit efficient over Gen 1 (which is pretty damn good begin with). The 300, run it on high test 93 closer to 320. run it on 87, 300 HP. Merc says 91 or 87...The fuel burn numbers go up with low test is all from numbers have seen by owners of the 300.
Summation-fuel costs should be better on Gen 2 Verados than Suzukis until you get over 5500RPM, by double digit % efficent gains across the range for Gen 2 verados up till 5500RPM. Merc has a report to this effect comparing 300 Suzi to 300 Verado but stops at 5500RPM. Plenty of reports out there non merc from owners on running 87 in 300 Verados and fuel burn.
~13K is a steal of a price for a 250 Suke. No brainer there.
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
