Old 08-01-2009, 05:34 PM
Default Re: Electrical Wiring in South Florida
Also you'll need a crimper tool and a couple boxes of butt connectors red and blue and go rock'in -
be sure to pull 2 extra pairs (4) wires through when you pull - makes adding stuff and/or replacing a glitch easy - If your fat and old like me, get everything down in the boat so you just have to roll around rather than get up
i want to add a little to your suggestions. make sure the wire connectors are at least heat shrink connectors. also with the pulling the extra wires is a great idea. i also left a few extra pull strings in my cable run as well. you can lube the wire your pulling with some dish soap. sometimes will make them slide thru very easy.
