Make sure you get a positive flotation type bracket that can offset the 4-stroke weight. I recommend the Hermco Bracket with a single mounting. With this type of setup & having your self bails drain out the transom should work just fine. I would recommend the cross drain method should twins be your selection.
There are many threads on this site that include pictures on this subject. Use the search function and enjoy the reading
