Old 08-25-2009, 07:42 AM
Default Re: Help with 18' SeaCraft Project
no such thing as a stupid question . . . only stupid mistakes!
Yeah. Usually caused by not asking questions in the 1st place.
Regarding trim tabs, I use them primarily for lateral (side-to-side trim). A deep-V will tend to lean into the wind; the wind blows you off course, so when you crank in some rudder to correct, boat will roll in the direction you turn the helm. When you lay a deep-V on it's side, it's NOT a deep V anymore! When waves are coming at you at some angle off the bow, rolling the boat just a few degrees AWAY from the waves with the trim tabs increases your deadrise relative to the waves and will create a big improvement in the ride!
...Also if you're stern heavy, a 4 blade prop will also give you some stern lift.
Excellent advice!!
Fr. Frank says:
Currently without a SeaCraft
