Old 09-03-2009, 12:55 PM
stanley stanley is offline
Default Re: Another trailer problem.boat won't load right.
I had a 23 Formula which has a deep V similar to your boat with a roller trailer. I had the same problem loading my boat on the trailer as I used to partially drive it on and winch the rest of the way. Problem was when I was in the boat because of the V it would list to the right a bit. When I would drive it on it wopuld continue the list to the right because of the weight. I guess u need to make sure the boat sits perfect in the water and does not list to one side because of batteries or oil tanks etc. Once you are square in the water it should come up even....just a thought
