Old 09-15-2009, 12:47 PM
mancinema mancinema is offline
Default Re: Everything you ever wanted to know about AWLGRIP
I’ll get the ball rolling.
I haven’t painted or even ordered any of this yet. I’m hoping your feedback will help me get the best results and prevent me from over-ordering and or killing myself with isocyanates
Awlgrip products used & price paid:
White 545 Primer $117 gallon
Primer Converter $109 gallon
Primer Spray Reducer $24 quart
Snow White $208 gallon
Sea Foam Green $311 gallon
Top Coat Spray Converter $228 gallon
Top Coat Brush Converter $68 pint
Top Coat Spray Reducer $70 gallon
Top Coat Brush Reducer $29 quart
Griptex Non-Skid $39 quart
Supplier: Jamestown Distributors
Equipment used for application: Harbor Freight Gravity Fed HVLP gun with CAPSPRAY CS8100 3 stage turbine borrowed from a friend.
Coverage:
-20SF Seacraft-
This is what I’m thinking…
Hull: (2 coats primer + 3 coats topcoat)
2 Quart Primer
2 Quart Primer Converter
.5 Quart Primer Reducer
2 Quart Sea Foam Green
2 Quart Top Coat Spray Converter
.5 Top Coat Spray Reducer
Inner Liner (Not including floor): (2 coats primer + 3 coats topcoat)
2 Quart Primer
2 Quart Snow White
Rod Storage & Anchor Locker: (2 coats primer + 3 coats topcoat)
.5 Quart Primer
.5 Quart Primer Converter
.1 Quart Primer Reducer
.5 Quart Sea Foam Green
.5 Quart Top Brush Converter
.1 Top Coat Brush Reducer
Center Console: (2 coats primer + 3 coats topcoat)
1 Quart Primer
1 Quart Primer Converter
.25 Quart Primer Reducer
.25 Quart Snow White
.75 Quart Sea Foam Green
1 Quart Top Coat Spray Converter
.25 Quart Top Coat Spray Reducer
Deck Non Skid: (2 coats primer + 3 coats topcoat)
1 Quart Primer
1 Quart Griptex
Safety precautions used:
Gerson P95 isocyanate approved respirator from Harbor Freight
http://www.harborfreight.com/cpi/cta...emnumber=66554
Full Tyvek coveralls with hood
Goggles to protect my eyes (I’ve heard that isocyanates are drawn to moisture)
Nitrile gloves
Location & environmental conditions:
Backyard
September - 88 degrees with 70% humidity
Underneath a 10 x 30 White Party Tent Gazebo Canopy with Sidewalls
http://www.amazon.com/White-Party-Ga...3026992&sr=8-4
Tips & advice:
1. I called Awlgrip and they recommended using gelcoat NOT Awlgrip inside fishboxes or anywhere that might have standing water.
I hope to have a lot more tips & advice about Awlgrip for everyone once I actually start working with it
