Old 10-09-2009, 05:46 PM
Guest
Posts: n/a
Default Re: 20SF Wiring Redo
I also have found numerous wire pieces taking up space and going nowhere! Spent time the last couple of days cutting and glassing in a mounting board under the console on the interior port side for my ground buss and fuse panel. I have a spreadsheet with all the equipment listed and assigned to a particular fuse and slot on the buss. I've got a new fused 6-switch panel wired and terminated. I am using heat shrink butt splices and terminals, and I soldered and covered teh solder connection with heat shrink on the switch panel. The heat shrink butt splices have the adhesive that flows when they are heated enough so no water can't get to the wire. I am trying to get as much of teh small, tight, connection work done on the bench before I mount things on teh board. I hate trying to work with wiring while on my back in an awkward position. I also pulled the transducer wire for my new GPS/Sounder from the stern to the console. I will try to post some pictures later this evening.
