Old 10-09-2009, 06:25 PM
Guest
Posts: n/a
Default Re: 20SF Wiring Redo
This is the back of the new switch panel. Each switch is fused. All the terminals are heart shrunk. This will be tied into the power buss on the fuse panel. A separate ground buss will be mounted on the backboard with the ground lead position for a piece of equipment on the buss matching the panel position location for that equipment.
This is the fuse panel. I am using this for equipment that does not need an on/off switch. It incorporates a ground buss right on the panel which I like. I can have the power and ground for an item use the same position on the panel. This makes for ease of location and troubleshooting or removal.
