Old 10-19-2009, 09:48 PM
Default Re: Seafari 25 performance
I'm glad to finally see a dialog about a 25 Seafari. Thanks, Connor, for posting your performance numbers. I have some thoughts, but understand that these are mostly based on investigation and not actual experience, since the only time my 25 has been wet since I bought it was when I left it out in the rain.
I really hate the single stick control on the seafari tabs and will be changing to a two button soon.
If your tabs are Bennett, you might consider their auto trim system, the AC 3000. The rocker switch assembly runs $50 +, which makes the auto tabs that much more attractive. My 25 has Boat Leveler tabs which have a rocker switch almost identical to the Bennett, so I'm assuming the AC3000 will work on them as well.
Has anybody tried putting extra weight, lead, concrete, whatever, way up in the bow of this boat? ...Maybe a couple of hundred lbs in the bow would help keep the stern from sinking so far. Might also damp the roll a little.
I understand it is very common to find ballast placed low and forward in these boats. Mine didn't have any, but I plan to place a fresh water tank under the cabin/cockpit sole forward of the fuel tanks to serve as both adjustable ballast, and fresh water for wash down.
Does anybody know how much room there is under the well between the seats at the aft end of the well?
The fuel tank compartment ends where the deck drops 6" to the cockpit sole which continues into the cabin. There is a plywood bulkhead under the deck at the transition. The bulkhead in my boat has a cutout that allows access to the space under the cockpit/cabin sole. This space has a sole that sits atop the stringers and tapers in width, and to a lesser extent height, toward the bow. I don't have exact measurements, but I believe I will be able to fit a 38"L x 20"W x 9"H, 25 gallon tank under there which will weigh a little over 200lbs. full. I plan to build a plywood mockup of the tank to test the fit before I order it.
Seafari25, the tandem trim tab setup is very cool and an ideal solution for these variable deadrise hulls. What was used as a linkage between the inner and outer tabs?
Dave
Blue Heron Boat Works
