Thread: Hole repair...
Old 10-23-2009, 01:22 PM
thedog thedog is offline
Default Re: Hole repair...
sounds good, how do you guys finish it? Do you mix up a little gel coat and then top off the marine bondo or 5200 to try to make it look nice?
if you just have small screw holes the finish will be ok just with the 5200
if the holes are larger bolt holes then it will not look so good then you open a new can of worms with either paint or gel coat
