Old 10-26-2009, 09:45 PM
todosier todosier is offline
Default Re: 1970 20' S/F Second Effort Total Refit
As far as weight, I'll have a 200# cabin forward, if that helps. I probably will go for a bracket to try to open the cockpit up as much as possible since the cabin steals quite a lot.
While I'm asking questions what thickness did you use for your floor and are you happy with it? Would you go thicker or thinner?
Withthe Coosa when you butted panels for the floor, did you just use a a piece of Coosa as a butt block like you would with plywood? Did you tape the joints after you installed your pre-glassed panels? Sorry, I could go on for days and days, I'll stop.
Thanks,
tod
