Did you check the compression when the engine was warmed up?? Also was fuel/oil running through it at the time of the test?(Kill switch in safe mode) All the plugs out at when you cranked it over??
Motor was cold when compression done
all spark plugs removed and remote starter used at motor
Tim... wish you were closer.....
I will check specs just in case..I really dont feel like dumping money in that I dont have!!!!
