Old 11-24-2009, 03:55 PM
Default Re: 1978 SF restoration, my first one.....
Caymanboy, the rigging tube terminates into the bilge compartment which would then leave the exposed cables to turn into the opening in the transom to access the bracket. Per someone else's recommendation on this forum I used the thinner wall DWV PVC because it weighs less but also couldn't locate a longer radius "sweep" that you describe. I need to investigate further because I don't need that to become a problem when I get to the point of pulling cables. Thanks for your advice.
Will
