I didn't think it whould be neat or easy. Is it necessary? Could a satisfactory deck be laid over this base? I may decide to open up and re foam fill the stringers in which case it is not an issue.
Two scenarios...if the base now is solid and not cracking or flaking and does not pull off from the stringers...yes you could rough it up and epoxy the floor down. However like WT mentioned do a check on your stringer foam by cutting a hole or two and see it its soaked. Then the point is mute.
