Re: Deck to stringers conection
Hopefuly I can inspect the stringers tomorrow. The foam between the stringers is wet but only down about 1/4 ". I can't imagine the foam inside the stringers is totaly dry because with a four stroke on a 20" transom theres always water in the bilge. Is any wetness in the stringers acceptable? Do you have to cut the entire tops of the stringers off to remove wet foam?
