Re: Whats everyone got for winter projects?
Long List!
-remove awlgrip below waterline hull and bracket, replace with either Aquaply M or Interlux VC Epoxy
-add radar,nw switch,another lowrance MFD LCD
-plumb transmom livewell maybe or plumb removable on deck livewell, add tuna tubes(for live bluefish) off transom and/or make them removable
-high speed pickup thru-hull
-salt water washdown
-fix rear hatch that lifted up over old engine i/o area
-rig up outriggers for dual lines per side
-add more swivel rod holders
-attach EPIRB to t-top
-attach fire extinguisher per CG rules somewhere
-determine if keeping transom mount Sounder or go shoot rhu or thru hull
-replace crappy 360 light with LCD light on t top
-figure out tuna slide or teeter board or gin pole approach
-troubleshoot high water bilge alarm(again, already replaced faulty switch once). espesh if plumbing transom livewell!
-rebuild 5xpenn old 113H for striper trolling with wire line and chrome/brass spools, and new 5 drag setup with new aluminum frames
-attend to all gear in basement!
-learn some more knots, re-learn knots forgot already
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
