Old 12-30-2009, 10:50 AM
tmtmv tmtmv is offline
Default Re: Foam in between inner and outer hull 23' Inboard
The foam would act somewhat like a core between the 2
If you take your hand and as run it down the side of the boat slap the hull and listen to the noise and also feel the flexing of the hull. I have run the idea by a couple of boat builders and they think it is a great idea. My first concern was that it might cause an osmotic problem but since air freely covers both outer surfaces I don't believe
it to be a problem. I'm going to try it around the chase where the fuel vent and gas fill goes.
