Old 12-30-2009, 03:43 PM
Default Re: Foam in between inner and outer hull 23' Inboard
....On this topic search this website regarding tank replacement and you will find many, if not most, were caused, at least in part, to foam holding moisture in contact with the aluminum tank with corrosion of the aluminum being the result.
Yep, See below....caused by a "foamed in" fuel tank.
