Old 01-10-2010, 05:10 PM
Default Re: I Need A Shrink !
Moving along. We removed the engine on Friday. Outdrive is in excellent condition with no corrosion. We are replacing the seal and bellows. The engine looks OK but is a little rough especially under the oil pan as there was some rust there. We will know more after we take off the heads.
Another shot of the hull
It's been wet and foggy here in N. Cal and the sun has not shown itself in my neck of the woods for over 2 weeks!
I moved the cap into the shop were I can begin doing some glass work. Yes I did have to do some grinding myself as there were lots of spider cracks and holes that needed to be carefully ground down. I'll post more close ups as I begin to fill those. I will be using vinyl ester for most of the glass work however I may use some epoxy in the bilge area were the motor was.
Another shot of the tower
I like the looks of the one on this Scepter
I think I will modify the existing tower which has a visor type extension and make it look similar to the one you see on the scepter. This will also give it more support and add two more legs that mount to the front of the cap.
More to come
