Re: in deck livewell
The only time I like that set-up personally is when the livewell is glassed to and is part of the hull. With a inlet and overflow directly through the bottom so when you're running it can drain out or you can close it off from inside the livewell and the thruhull at the same time. If done correctly it really gives you a huge safety margin compared to hoses and plumbing. Get the overflow at the perfect height and the center inlet at the right height and it works great. Don't know how well that would work in a smaller boat on smaller scale, not much room. Livewels can be pretty creative and there are a bunch of different setups. I'll be figuring one out soon. Good luck! Bruce
