Old 01-29-2010, 09:06 AM
trave2 trave2 is offline
Default Re: Pictures of the new boat EMANON
When the boat was redone they only replaced the center decks above the fuel tank with new foam core decks (bolt in). The outside deck was in good shape, no soft spots and solid, stringers too. The boat was barn kept in GA for years he said, thats where the previous owner picked it up. Yes at some point the outside decks will need to be redone but I don't see that happening for decades. Even the transom was solid and dry when they raised it 5 in to match the 30in motor. The gelcoat is orig as well, compounding right now! minus the small scratches for a 24 yr boat.
Anyone know the best or easy way to hook up the throttle control for the upper station, cables already run to the console, terminated at the existing binicle, single yamaha binicle? Can I get a dual binicle shift and throttle(side by side) and Plug-n-play? The steering is hooked up and works great.
Also does anyone have a Furuno sounder bbff1 or the new dff1 (black box) they want to get rid of? I have a airmar thru-hull transducer waiting to be hooked up!
