Thread: Fuel Tank Help
Old 02-01-2010, 07:48 PM
Guest
Posts: n/a
Default Re: Fuel Tank Help
Don't use any type of RTV or anything with silicone in it, as it's not compatible with gasoline.
Absolutely right! Permatex 2A is the way to go. However, I would use Permatex #12020, Instant Gas Tank Repair between the gasket and the tank if you have any pitting under the gasket.
I went with the Permatex 2A. The pictures look like pitting, but it is just crud. I cleaned it off and it is now back together. I have the tongue of the trailer down so the fuel is away from the port. I'm letting it cure overnight and I'll be checking to see that it does not leak in the morning. Thanks guys!!
