Old 02-03-2010, 02:53 AM
Default Re: are the 20'master angler more desirable?
They didn't come with any that I know of - we rigged the thru hull and sea cock at the dealer. Mine already had one when I bought it and then fills into the bottom of the well - although this wasn't a pretty install. The drain is just a standard 1 1/4" with a brass strainer thru the transom. I guess it might be possiable to exit the side but the well is pretty flush against the hull but would have a gap - that might wiggle a bit and be tough to seal. Be sure and mount the pump below the waterline or it won't draw right.
