Thread: steering issues
Old 02-09-2010, 08:39 PM
Default Re: steering issues
  • 1st, Remove any cowling parts that are near the motor pivot.
  • Remove the carburetors, fuel lines and fuel pump.
  • Disconnect ther steering cable or hydraulic ram.
  • Use an oxy-acetylene torch with a rosebud tip to heat the entire pivot column, without igniting the old grease. (Just warming it up)
  • Using a pneumatic grease pump, pump a very large quantity of strong petroleum solvent into the pivot grease fittings. (Use a cut 55 gallon drum base to catch excess solvent and grease).
  • To force solvent upward in the pivot column, you can wrap the base of the column with a rag, and then put a worm-screw clamp around it.
  • Pump new molybdenum grease (NOT LITHIUM GREASE) into column until it comes out everywhere. LOTS AND LOTS OF NEW GREASE!!!
  • Reassemble fuel system and cowlings
This is only a temporary fix. It could do you for a couple of years or more. A real fix means pulling the powerhead to access the pivot pin.
Fr. Frank says:
Currently without a SeaCraft
