Old 02-16-2010, 02:09 PM
bobbert bobbert is offline
Default Re: 470 (165 hp)Mercruiser in 20' Seafari
The engine will mate up with transom assembly. The problem is an alpha od will NOT install on a pre alpha transom assembly.So you are looking at swinging over the transom assembly, or using you pre alpha drive. Also the transom key hole has to be enlarged in a few areas and re-epoxied when using the alpha transom ass'y
Good luck getting ready to do the same up grade on a 65 Bertram.
