Old 02-27-2010, 03:22 PM
seastrike seastrike is offline
Default Re: Scupper replacement??
got the scuppers out,,here are the pics. wood block holding the scuppers is definatly wet but with a propper repair it wont be a problem. In your fix, i am a little confused?? Is the pvc piece permenant?? Basicly if i understand right, you gouged out rotten wood,,,capped off bottom of hole,,,inserted pvc,,,,poured epoxy around pvc,,, installed brass tube through pvc?? is this correct??
[image][/image]
[image][/image]
[image][/image]
