Old 03-11-2010, 11:07 PM
Default Re: Spring Project(s) 74 20SF
You will probably have some white left over. Remember that you mix equal parts paint with converter then reduce 25%...so 2 quarts of paint will yield more then a gallon of spray able material.
Duratec was mentioned in that old post...it's Ok to use duratec except I would not use it below the water line as you will want an epoxy barrier coat on first before painting. Duratec does make a vinylester primer and that would be Ok to use on the bottom.
What I'm doing on my 25 if duratec on the top cap and insides of the boat and 545 on the outer hull sides and bottom. Hope this helps.
