Old 03-15-2010, 12:27 PM
SeaPlusPlus SeaPlusPlus is offline
Default Re: Spring Project(s) 74 20SF
Had a change of plans this weekend. The weather turned out decent on Saturday, light rain on and off, so was able to get out on the boat and look around and inspect some things.
It's been nagging in the back of my mind that I needed to replace the deck. Unscrewing the console and leaning post brought up some nasty wood with it, other screws just spun in place losing all grip. A 36 year old floor was bound to have some rot, but I honestly could only find 2 soft spots, both of which were very small, everywhere else felt solid.
Inspecting some of the console screw holes in the deck got the best of me Saturday, and I decided that it would be stupid of me to not replace it now, instead of in a year having to rip everything back up, cut out the floor, and repaint the deck. If the weather was nice Sunday, I'd once again take the saw to my baby and cut up the deck.
The floor was marked about 2" from the gutters/hatches/obstacles and the circle saw came out with a blade depth of 1/4".
Got nervous while cutting at the amount of good dry wood the was coming out of the cut, fearing that I was cutting up a mostly solid deck vs doing spot repairs.
Getting some of it up though I found lots of wet and rotten wood.
LOTS of wet and rotten wood.
Here is what the bottom of the glass looked like once it came up.
Removing the top layer of glass was easy for the rotted parts, but for the very small areas were the wood was good it was a pain to get it to delaminate. Once the pieces were out, a chisel was used to remove all the coring still stuck down, most of which could be just picked up in whole 5" pieces of plywood. Shop-vac and broom used to clean up most of the little stuff.
The floor still needs some chiseling around the edges to clean it up, and then needs to be lightly sanded. I plan on putting down a thin layer of glass to toughen up the bottom layer of glass where needed. On top of that will go 3/8" marine ply coring encapsulated in resin, and then the decking that I cut out glued back down on top of that.
I was amazed at how much of the deck (about 80%) was rotten and how few soft spots I felt, had no idea it was this bad. Even though its depressing seeing no deck in her right now, I'm glad I did it, she needed it.
Also playing with the idea of getting some 6" x 12" x 1/4" thick stainless plates to fiberglass into the deck, which can be drilled and threaded later, to provide something for the t-top to be mounted to, rather than screwing it in, or cutting two holes in the deck on either side of the console to thru-bolt it. Thoughts?
