Old 03-19-2010, 12:38 PM
trave2 trave2 is offline
Default Re: In deck Livewell issue
Some good ideas thanks! Squido thats what I had in mind too. I have a jabsco pump already plummed to the well w/ a clam shell on the hull. The problem is that it will not empty or circulate water. The bottom hole in the well is a straight shot to a seacock in the transom under water line, I'm thinking of removing that line or putting in a Y fitting and putting a pump out to the hull above water line like you are doing. The jabsco evacuation pump (fish box pump)is what I had in mine for pump-out. You might want a bigger gpm pump for the outflow just in case. Thanks for the tips and let me know how yours turns out.
