Old 04-04-2010, 07:21 PM
Default Re: center console location
Although the console may be in its original position, keep in mind that it was originally designed for 275 lbs of motor. Your VMAX is probably over 450.
You may consider moving your console forward to the point of a safe and balanced ride or as you mentioned swap out the motor.
The etec 90 is 325lb and would get you great efficiency and solve the weight/balance issue. I believe Tohatsus direct inject TDI 90 is 325lbs, also and generates the most power in that class. Evinrude v4s are also low threes as well. Sounds like you're a Yammie guy so you might consider the 2-s 130hp @ about 360lb.
Either way moving your console to improve your center of gravity and balance will always help your ride, and your sure to exceed 35mph WOT with virtually any of these motor classes.
