Old 04-07-2010, 04:10 PM
Default The Sleeping Shelter
Got this stuff at HD also Garden Dept, its a sun shade stuff
I will include a pic of the cushion rolled up - was getting worried the other post was too long
rolled up cushion
The piece and the helper dog
The grommits - they are 2 piece and you whack them with hammer and cut the center out - makes sizing easy - I will just use the alum. clips next to the cashier at HD to clip to the T Top
and then the high tech bow mount
just drilled a hole on each end and put 2 little bolts thru to hook the grommits on. NOTE - I will cut the main piece with a screw coupler to give some strength - allow it to have another hieght setting and storage
I have a hause pipe in the bow that allowed this to work, worked into the rope it worked fine
I will get some pics when I go out and use it
