Old 04-25-2010, 10:43 AM
Default Re: A bracket for 25\" 150hp on 20' CC- Pros & Cons?
-Can I glass in ply over the cut out? Strong enough or do I have to re build the whole transom solid?
*** Since the cut out area is not structural . . . you can glass over ply to fill the open transom.
-What is the way to go- Glass bracket or Aluminum tube style?
Either is fine . . . Fiberglass won't pit or corrode like aluminum. You will want a flotation bracket regardless of the material it's made out of.
-Are trim tabs necessary with a bracket?
Absolutely . . . without any question!!
Also . . . if you are redoing the floor and replacing the fuel tank, move the tank as far as possible toward the bow. The bracket makes the bow of these boats very light.
