Old 04-29-2010, 06:41 PM
zach zach is offline
Default Re: A bracket for 25\" 150hp on 20' CC- Pros & Cons
pretty sure you get flotation not due to weight but space within and displacement (but others know).
You are correct, but when running, which is when weight REALLY comes into play, the floatation chamber does nothing.
To the OP regarding set-back, I'd go as short as is necessary to fully tilt your engine up. Since you're building your own, you have this option. Yes, 30" is standard but I bet you can get away with a 25-26" setback, maybe shorter. Not too big of a deal but every little bit helps.
I also think it looks more proportional with a shorter set-back.
