Old 05-01-2010, 06:00 PM
MakoMike19 MakoMike19 is offline
Default Re: New Member, New Seacraft 18
some fresh carnage. Plan is to build up the transom from the outside-in. That way I can tie into the inside of the side-walls and not worry about the fairing. Also, glassing upside down on the bottom would be near impossible. (vacuum bagging would be about the only way)
nope, i didn't cut the tops of the stringers off. Not sure why they are missing. at least the foam is dry
I'm leaving the inner skin on until I get some supports across the back so the sides don't bow out.
Also, that livewell was a pain! And built like a freakin tank! Some of the glass was almost a half inch thick.
The center stringer is toast, so the entire floor will be coming up later. Guess they forgot a little glass here:
