Old 05-08-2010, 10:21 PM
MakoMike19 MakoMike19 is offline
Default Re: New Member, New Seacraft 18
Got some grinding done today, GRIND GRIND GRIND. Mostly done, need to get the 2 inch out to touch up corners and edges, and remove the gel coat.
In other news, found some water intrusion under 2 layers of glass that seeped in from the stringer. Was grinding away and saw some black glass, so out it came. Was still small amounts of water underneath. The shaded area is where I found it.
Also finished the rear mold and cut out a transom pattern.
