Thread: Bracket help
Old 05-20-2010, 10:17 PM
nate22 nate22 is offline
Default Re: Bracket help
Ok I went out and got some measurements today.
The setback is 30in not 42in.
The span of the mounting surface is 42in.
It is 6ft wide.
The hight of the bracket from the lowest part (the V) to the highest part, were the engine bolts up is 19in.
Also my engine is a 25in shaft motor. I know the Hermco twine engine bracket requires using a 30in shaft motor, is the Armstrong brackets the same? can my engine work with this bracket?
I will try to get up some pics,
thanks for the help
