Re: Bracket help
It would not work because my motor has a 25in shaft leanth.
If I had a 30in shaft motor I can mount the bracket 5in higher, and clear the bottom of the transom. The Armstrong bracket is 3 1/2ft wide at its mounting point in the front.
If I mount the bracket 23in from the bottom of the transom, the lower sides of the bracket flotation part will protrude out the sides of my transom, which will cause drag.
