Thread: 18SF rebuild
Old 05-25-2010, 09:40 PM
adamcannon adamcannon is offline
Default Re: 18SF rebuild
I got a question for you, I noticed in the back of your stringers you had some holes presumably for draining. Did you have any hoses or tubes running thru them, or wet foam?
There were holes going thru the stringers in the back and also in the front. They had tubes running thur the holes but they didnt really waterproof between the tubes and the foam. The only water that I found in the foam was right around the holes. It wasnt bad at all. I am going to cap off the ends of the stringers with glass and then extend one side of the stringer to tie into the stern. I dont see the need to take the whole box stringer all the way back to the stern like it was.
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
