Thread: 18SF rebuild
Old 06-08-2010, 03:09 AM
adamcannon adamcannon is offline
Default Re: 18SF rebuild
When I cut out the front of my tank coffin to install a 60 gallon tank, the only place I saw the putty was on the stringers and where the drain is.
If that is the only place then that would be good. Is the drain you are talking about the one that goes thru the hull in the back of the box? We are going to try and pop the remaining top deck, casting platform, and forward storage box out in one piece. We were thinking if we can do the structural glassing on the bottom side of the liner the finish work on the top side might be easier. Im not sure how big of a job that will be though. If anyone has popped the liner out of their boat before let me know because I could use all the input I can get on that. Thanks for the post.
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
