Thread: 18SF rebuild
Old 06-09-2010, 11:23 PM
adamcannon adamcannon is offline
Default Re: 18SF rebuild
Well tonight we got the pilot holes drilled in the bracket and thru the transom for the bracket bolts. We wanted to go ahead and drill thru the transom so we can fiberglass some 1/4" solid fiberglass panel on the inside of the transom where the bolts will be. I am hoping this will help spread the compression out from the head of the bolts when we mount it permanently. It will act like a backer plate. It probably doesnt need it but I want to make sure the transom is plenty strong where the bolts go thru. I was a little worried that there wouldnt be enough clearance between the bottom of the bracket and the bottom of the boat for the trim tabs to mount. After we marked where the bracket would be I held the tabs up to the boat and they fit just fine. That was a big relief. I will post more as we make progress. Thanks, Adam
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
