Thread: tank install
Old 06-13-2010, 06:05 PM
BigLew BigLew is offline
Default Re: tank install
TRL5,
If I may, pls. re-read the part about 5200. 5200 is applied to the plastic bed strips to preclude any moister becoming trapped against the aluminum. The tank is NOT recommended to be 5200'd to the shelf/base where it sits, but rather just set in place using the weight of the tank + fuel to prevent shifting. Most of the tanks I have seen, including mine have some aluminum tabs welded to them and then those tabs are screwed into the sides of the well that the tank/coffin is set into. A fine point yes, but think of someone trying to remove a tank 5200'd into place. THAT would be a "NIGHTMARE on ELM STREET"(and any other street as well)!
Plan accordingly!
