Thread: 18SF rebuild
  #26
Old 06-24-2010, 10:52 AM
Default Re: 18SF rebuild
We wanted to go ahead and drill thru the transom so we can fiberglass some 1/4" solid fiberglass panel on the inside of the transom where the bolts will be. I am hoping this will help spread the compression out from the head of the bolts when we mount it permanently. It will act like a backer plate.
Another option would be some ss square washers say 1/4 inch thick and 3 inches square. That would probably be stronger then the fiberglass panel.
I am going to use awlgrip paint on the outside of the hull, bracket, console, and top deck. I was wondering.....would I be better to use awlgrip paint and nonskid on the floor or should I use gelcoat on the floor. I am thinking of going with Aqua Mist color. I was wondering if anyone has used this color and if they have any pics of it on a boat.
Since you are already using Awlgrip I would just use that for the nonskid...it's tough stuff. Get a color that hides stains.... Awlgrip is easier to work with then gel coats.
Boat with aquamist color: http://www.classicseacraft.com/forum...=&fpart=1&vc=1
