Old 06-24-2010, 11:04 PM
nate22 nate22 is offline
Default Re: all this work for a boat ride!
I got a question on the location of the through hull transducer on this hull. I am trying to decided on if I should keep the existing hole, or patch it up and drill a new one.
The hole is located about 2 1/2 feet from the transom 1ft from the centerline of the hull, hard against the 1st step up in the hull. An Airmar model like this one came out.
Airmar B45
I plan on installing a new Airmar B60 transducer to replace the current one.
Would the existing place of the current hole be an ideal location for the Airmar B60 transducer?
Also what type of seacock should I look out for to replace the old one that came out of the hull?
thanks
By nat22 at 2010-06-24 Airmar B60 Airmar B60 Airmar B60
